What tyres RR4
Discussion in 'Maintenance' started by Rr-Len, Feb 28, 2015.
  1. Warren
    Warren New Member
    Don't know about the hugger clearance to be honest, I found this link for you... http://www.sportrider.com/five-percent-difference
    and I read this on a Yam forum which you might find useful ;)....
    Originally Posted by blacknzr1 [​IMG]
    i was reading of a guy with a 07 r1 who claims a 190/55 rear tyre gave him a lot more grip over his stock 190/50 rear tyre.
    im not sure what to make of that statement, weather its true or not...
    has anybody else done this??
    what do you think??
    MY .02:
    The 190/50 is going to have the same CONTACT patch as the 190/55. The grip part is going to come the tyre compound itself!
    The 190/55 is a taller tyre than the 190/50, this just allows you to turn in quicker.
    Will you benifit from a 190/55, yes. It is cost effective for the street? Depends on your taste. Most likely you or your buddy won't use the potential of a 190/55 vice a 190/50 on the street anyway.
    As for your buddy having more grip because of the tyre size - not so much as the compound.
    Also running a taller tyre will change your geometry - so look at resetting your suspension.
  2. SimonRR
    SimonRR God Like
    Taller tyres have a larger contact patch at lean, also tip in better, hence a lot of rear slicks are a larger profile
  3. BoroRich
    BoroRich Elite Member
    I can only share my experience.
    When I switched to a 55 profile, the bike just felt much more nimble and a bit more planted on lean. I was well happy with my choice to switch.
  4. rickross
    rickross New Member
    Maxxis Diamond 190 55
    I have done 6k miles already and will use for another 2k.
    Much difference comparing to size 50 and I can get them for £139 pair.
    No need to buy dunlops bridgestones or pirelli.
