Who tightens their oil filter by hand?
Discussion in 'General 1000RR Discussion' started by Phpbiker, Jul 8, 2014.
  1. trisers
    trisers Active Member
    As said before, clean the mating surface, light film of oil on the seal then spin on by hand until it touches...after that tighten 180 degrees...
  2. restone
    restone Active Member
    I just oil the the seal and do by hand.......trouble is I have to muller it with strap and cam tool to get it off as a stonemasons hands are a rather blunt instrument. As a result of this I've moved to K&N filters so that I can use the torque wrench.
    Like wise I've bought a set of the three torque wrenches small medium and large as I'm sick of overtightening things by hand.
  3. Phpbiker
    Phpbiker New Member
    I fucking don't having used the tool to do it up I can't undo it...and no I won't bang a screw driver through it
  4. Trouge
    Trouge New Member
    Torque wrench on my old gixxer. Not done one on the blade yet.
  5. Jc04
    Jc04 New Member
    Only ever tightened filters by Hand ,not had one filter come loose, I've had a sump plug come out as an apprentice hgv tech but that's another story, One I could never forget! But, I would torque it if it had a nut on the end cause there's nothing like piece of mind and knowing its correct as I learnt the hard way :eek:
  6. maxxuk
    maxxuk New Member
    From "The Book":
  7. maxxuk
    maxxuk New Member
    ...nut on the end :D
  8. SimonRR
    SimonRR God Like
    Well even I would torque one with a nut, might have to go K&N next time then :D
  9. lambchops
    lambchops Elite Member
    I always hand tighten.. Never had any troubles but I do have hands like shovels lol
  10. Jc04
    Jc04 New Member
    Yep didn't know that +1
  11. Phpbiker
    Phpbiker New Member
    Well there you go.. That's why I can't undo it.. I did it up. Properly...
  12. Phpbiker
    Phpbiker New Member
    You need a wrench for this job because of the fairing ..you don't have to remove the fairing with the wrench. And with it on you defo wont get the filter tight enough.so don't try IMHO
  13. Waterblade
    Waterblade New Member
    By hand and then slightly more with a tool, don't think it really requires much.
