Winter hibernation
Discussion in 'General 1000RR Discussion' started by Julian, Oct 26, 2013.
  1. Clarkey
    Clarkey Member
    Can't believe what I'm reading that some of you don't ride in winter
    I've had some fantastic rides in winter you lot are missing out
    If I do go out I just make sure you I give the blade a good clean
  2. Nutty Tart
    Nutty Tart Well-Known Member
    Yup I had a rideout on Christmas Day a couple of years back . We were eating at mums in the afternoon so I had a couple of hours to kill in the morning . I have a heated jacket and gloves and was really toasty . Can't beat it :)
  3. Jimbo Vills
    Going out in a minute. Suns out, it's Sunday. Why not?
    Pretty sure we still have a few weeks of autum yet?
  4. abv
    abv Active Member
    Just got back from a couple of hours round the local twisties great fun, fresh air and sunshine :)
    As soon as the leaves have all gone you can really get a shift on with the better sight lines available.
    The only thing I avoid is the salt.
  5. rocket
    rocket Active Member
    mines full of fuel and i don,t bother starting it at all as to warm it properly you need to ride it and load the engine up a bit. mine will sit there 3 months or so then on the first time i,ll spin it over with kill switch off for 10seconds to pump a bit of oil pressure up then start her straight after. if you use an optimate DON,T leave it permanently on. just a 3-4 days at a time once every 3-4 weeks. i,ve wrecked 2 batterys in different bikes by leaving it permanently switched on.
  6. just_me _and _me _bike
    Ive never owned or used an optimate in 10 yrs of biking and if im honest i dont see that ever changing.
    We do get sum really sunny albeit chilly days throughout winter where u can take the bike out for a spin, even if u do a 10 - 20 mile ride out this is much better than letting the bike idle on the drive for 5, 10, 20 minutes, as A) its a waste of fuel, B) ur neighbours will think how annoying n daft is that C) The roads r dead, no fair weather straight line heroes or even cops about so u ca ger a nice lick of pace.
    And wot better feeling than pulling into a. Nice pub for a drink n bite to eat infront of a roaring fire before riding home again :)
    I do ride all year, unless its black ice or snow on the roads n im not a fan of the rain anymore, but if you strip off the fairings and give the bike a real good deep clean after EVERY ride n you will def keep the furring n rusting at bay :)
  7. Freedom of choice
    What others have said, bike off the floor, neck the tank, battery indoors if the garage isn't heated, and leave well alone till spring, spin engine up with kill switch on to get the oil round before you fire it up. I also drain the fuel and put fresh in before I start the engine, the old fuel should be fine but I always put it in my other half's car, if it has degraded, it won't be much and not noticeable when added to fresh fuel in a car tankful.
  8. ShinySideUp
    ShinySideUp Elite Member
    Well I'm just back in from the post office after sending tax disc away for refund on remaining months!
    We get very few and far between dry days up here through the winter and combine that with the constant onslaught of gritter trips dumping each day the temps get anywhere close to 0!
    I was out on the bike last week for my last dry sunny spell and the bikes coolant temp that normally sites arounds 82 degrees in mid-high teen ambient temps was runnin at 64 degrees on the way home (sun still out but going down fast) where I proceeded to loose feeling in hands and other extremities and it took ages to gain normal body temps when I got back home!
    The bike will be in the garage but not strictly put into hibernation for another month or so as I tend to strip the fairing and wheels off n give her a good old clean, scottoil covering and at the same time fit any new additions that I have bought for her.
    I also tend to use this time to do my servicing so all new fluids in the machine, fuel tank brimmed I also remove the battery where I charge this n every couple of months put it on for a topup.
    I don't bother with the starting the bike through winter to let it heat up n switch off as I find it just draws more condensation as its very hard to get it up to proper running temps without riding it!
    As for the fuel degrading that more effects the American market the UK and pretty sure most of Europe refines the fuel more than the US and degradation although it does happen to UK fuel it does so at a lot slower rate than that of the lower octane fuels.
  9. t0m541
    t0m541 Senior Member
  10. sps170373
  11. sinewave
    Bought one of those off Demon Tweeks.
    Bout £120+ VAT including adapter! There's a good video on the link below!
    That's cheap in my book, duno about yours?
    Warrior Spider Stand - Demon Tweeks
    #31 sinewave, Oct 28, 2013
  12. sps170373
    Cheers sinewave
  13. Island Rider
    Island Rider New Member
    Cheaper than an ABBA stand with the front lift package....was thinking of getting an ABBA stand but this looks better as you can move the bike around, does it have a brake?
    Seems like a good height to work on your bike or wash it, hate bending down due to back problems.
    Need to order a stand soon to put my bike to bed :mad:
  14. explorer
    explorer Member
    I've just sorned the blade as tax was due, will use the triumph over winter for any nice days, usually leave on optimate for a couple of weeks at a time, although last winter left it on for a few months, battery was fine. Will change oil in spring.
  15. Slick
    Slick Elite Member
    Meh hibernation!! rode mine during the snow and grit!:D..........
    ...... but this year I've bagged an old CB so will probs run it during the really bad spells. 1 question though, should the suspension be loaded during storage? ie abba or paddock?
  16. just_me _and _me _bike
    Ya mad bugger!! ^^^
    :p
  17. Alblade
    Alblade God Like
    R1 is sorned till April
    Blade is off road for some initial repairs post Spain / France problems.
    Quite enjoy a winter ride on dry leaf free roads - high pressure days = cold, dry and bright.
    Have been snowed on New Years Day at the Cat and Fiddle pub one afternoon!
  18. ShinySideUp
    Kudos on the winter wonderland riding experience but I keep the four wheeled box for those times it comes with heaters and a radio it can also lug a lot more gear about when required! :D
  19. Andy
    Andy Active Member
    No freaking way would I even consider going out in that on two wheels.
    Respect
  20. Dave V
    Dave V Elite Member
    The only thing I'd add is the use of ACF. If planning store the bike it will help combat any moisture in the air, if riding through winter it's the nuts in battling against corrosion.
    Just hose the bike down to get the salt off after every ride, that's if you don’t have time to properly clean it.
