Wiring diagram for RR-04
Discussion in 'Maintenance' started by IcarusGreen, Aug 7, 2012.
  1. BLAGGERS
    BLAGGERS Well-Known Member
    Wish I could see that feckin drawing.....
  2. phantom
    phantom Active Member
    also check the starter switch as it cuts the power when you start the bike
    and if its shorting that will also kill your headlights
  3. phantom
  4. IcarusGreen
    IcarusGreen Elite Member
    Thanks, I'll check that tomorrow.
  5. martinowen
    Yea thats the one it's on the right. I ment when I changed the nose come over for my new one, I'm not that bad lol
  6. phantom
    picture hosting
  7. IcarusGreen
    I've now found the fault. It was a loose connection in the cut off switch. The headlights get a constant feed through the starter switch which keeps the headlights on at all times, the loose wire stopped this constant feed.
    The reason the headlights then worked using the pass switch is because it gets its fed from elsewhere.
    tempory bodge underway and a new switch being ordered tonight.
  8. IcarusGreen
    Just seen £60 for a new switch! How fookin expensive. Good be a flee bay buy for nearer £30!
  9. martinowen
    Glad it's fixed mate
  10. IcarusGreen
    I've managed to fix the switch and so for the forceable future I will not need to fork out silly money for a switch.
    The problem with stripping the bike right back is that you see all the dirt and grime that gets under the fairing, therefore stage one of cleaning already carried out and tomorrow will be stage two and some anal touch up points that only i'll probably ever notice.
  11. martinowen
    I know what you mean, I had a spider nest behind my nose cone
  12. phantom
    good job, at least thats you back on the roads at night again lol
  13. BLAGGERS
    a thousand apologies............. only just got my fookin computer working again. i recently had a roof leak and it pissed all over the thing, stripped it ,dried it and tried it. t'was ok but it decided to melt a pcb.....bastid.
    well at least its sorted now, like your lights.
  14. Tyson (TPR Powersports)
    True, I've been a Honda tech for over 20 years and have seen this exact issue on many Hondas including my own 01 929RR, I'm not sure why but for some reason VTR1000Fs were particularly vulnerable to this... The start button has two sets of contacts, one which power the starter relay, and a second which drops-out the headlights during starting to save some power. When the headlight contacts get dirty/worn/burned the headlight may not come back on. This would be the first place to look and the most common cause if all lights aren't working. On most bikes a simple rub with fine emery paper and clean of the metal contacts gets it working like new again, just be careful when ever you're taking apart a switch block as there are many small screws, springs, balls etc which can be easily lost, and locking tabs which can be broken if not dismantling correctly.
