Yoshi R77 has landed! :)
Discussion in 'Mods, Upgrades, Accessories and Products' started by Shing90, Mar 12, 2013.
  1. Jase
    Jase Elite Member
    For Information I got my Carbon Yoshi noise tested at oulton park today it came in at 101db with baffle in at 5.5000rpm there limit is 102db. So it just passes for track day if you dare take you pride and joy on a track. :D
  2. rocket
    rocket Active Member
    only tricky part of fitting is the fitting of the long bracket that comes thru the s bend of exhaust to attach the fill in panel too. most people seem to fit this bracket first (iirc it bolts where old can was bolted too underneath bike) then assemble the link pipe around this bracket then fit can and tighten and fit springs. i had 2 fiddle around with the panel for a perfect fit but its well worth it.
  3. fez.57
    fez.57 Well-Known Member
    Well the exhaust went on a piece of piss, not had chance to line up the infill panel yet
  4. Shing90
    Shing90 Active Member
    No pressure then. Lol.
  5. fez.57
    Well i say that, i would put a small amount of lubricant on the link pipe that connects to the exhaust as mine was a little stiff, if you do this then i dont see any problems
  6. sinewave
    You can't beat a small amount of lubricant on 'the link pipe'! :D
  7. thezipsteruk
    thezipsteruk Elite Member
    especially if its a 'little stiff'
  8. fez.57
    Well i managed to keep my leo vince infill pannel on with the yoshi can. it doesnt fit 100% like it did with the gpr can because of the stupid mounting bracket welded to the exhaust but it fits good enough. sounds good aswell evrn on 2 cylinders lol
  9. Shing90
    Did you not get the Yoshi heat shield/belly pan extension then Fez?
  10. sinewave
    Nice Youtube Video, see what you mean about the sound! :rolleyes:
  11. fez.57
    Yes i have the yoshi infill pannel but its black and my belly pan is white so it would look a little daft if i fitted it.
    I started it this morning to drop it off at my local bike shop and when i turned around to lock my garage the bloody thing backfired, lets just say its a good job i have full control of my bladder
