Important Notice - Please Read If You own an ABS 2009 Onwards Model
Discussion in 'General 1000RR Discussion' started by jimglasgow, Jul 8, 2013.
  1. Dartmoor Dave
    Dartmoor Dave Active Member
    Top Man!
  2. Denis
    Denis Active Member
    Hi where can I find workshop manual?
  3. derchef
    derchef Well-Known Member
    did not read your presentation...
  4. Dartmoor Dave
    If you go back a page derchef says he posted a pdf version online. You could track that or if you want a genuine manual up to 2010, pm me for a price and pp. Its an 08-10 one incl abs.
  5. Denis
    Denis Active Member
    thanks will do
  6. Denis
    Denis Active Member
    Sorry another question
    My abs light flashes very fast
    There is no break between the flashes for there to be a code
    I am ready to bleed it
    I have followed the advise to put it in the mode to bleed but it just keeps flashing
    I have shorted out the green wire to the earth side of the battery is that correct?
    Please advise
    Thanks
  7. Denis
    Denis Active Member
    Hi derchef
    Where can I find your pdf file please
    My fireblade is a 2011
    I have the abs light flashing all the time
    My bike is stripped down ready for me to bleed it
    I have tried the other pdf file and it won't work on mine
    Many thanks
    Denis
  8. Spartan Andy
    Spartan Andy Active Member
  9. Denis
    Denis Active Member
  10. Slick
    Slick Elite Member
  11. derchef
    uploaded nother time "Swiss" guide as old links are not more available
    http://www.filedropper.com/c-absbleednotesv3
  12. Denis
    Denis Active Member
  13. Denis
    Denis Active Member
    Many thanks
  14. Denis
    Denis Active Member
    Hi slick
    My abs light stays on for about 9 seconds
    Then flashes continues
    No break between flashes
  15. Slick
    Slick Elite Member
    The DTC is only shown when you turn off the bike, short the ABS connector and switch back on. Sounds like you are not even getting pass the pre start checks.
    Get the DTC and that will narrow you route of investigation
  16. Swiss T
    Swiss T Active Member
  17. Denis
    Denis Active Member
  18. derchef
    is pretty easy , may for your safety is better bring the bike to a workshop
  19. Denis
    Denis Active Member
    No not really
    I wouldn't let anyone work on my bike thanks
    I have fitted a 2014 ecu and found a pump fuse that was blown didn't realise it had 3 abs fuses,
    Have now bled it all as per instructions and all looks good,
    Just need to ride it to test it now,will update when I have!
    Ps there was a lot of air in the system
  20. Blackgreg
    Blackgreg New Member
    What would be the best way to test if my ABS has the same problem? I just got it and I have only done 30 miles on it and I don't want find out on track that it fails.
